I am working on a friends M35A2. She was hard to start and I though it was a fuel filter issue. Replaced the filters and she would fill the primary but not the secondary. Tried to do a pressure test at the tank but the pipe plug in the test port was frozen. Finally rigged up a pressure test and got a 1psi reading. Pulled the pump and found this.
![pump.jpg pump.jpg](https://www.steelsoldiers.com/data/attachments/370/370424-354ead825b5332647230897b9b6128c8.jpg)
I have seardched here and found several references to using a $50 pump from ebay. Looking at it it doesn't have the steel wrapped wire and has instead what looks like to me a Douglas Connector like on my M37.
Question what is involved in modifying the wiring to work?? (Don't want to blow up my friends truck)
Second question is having the bottom fall off the pump a common issue??? I saw several posts that had this as an issue.
thank you
![](http://thumbnails110.imagebam.com/39156/a7c577391558107.jpg)
thank you
