R Racing
- 16
- 38
- St. Leonard, MD
Got my MEP-806a started today. Engine runs great !! But have a under voltage light. Frequency wont go above 51.5 hertz and the 110 outlet puts out 22 VAC ? I have been reading the TMS for over 4 hrs and checked a few things. The big issue I see in the TMs is they cover either or problems but not both tied together ? Tried the 50 hz /60hz switch. It works but on 50 Hz The voltage and hZ drop way down. On 60 Hz the engine sounds like its doing in the plus 2000 rpm. If you you turn the frequency pot. The RPM does increase and decrease , But the frequency moves like 1 HZ ? if you pull on the throttle just a bit on the pump . The engine goes into overspeed. I looked for broken wires and looked at the frequency transducer . Everything looks ok. anyone have any clues at all ?
