Tips on starting after siting for 2 years
Hottrodd789
Orlando fl
Looking for some tips on starting my truck in the next week after sitting for two years. New batteries new fuel new filters be everything.
the fuel line and fuel tank are all new so I have to get system primed up!
RAYZER
59
sanford/florida
You should pull the fuel shut off cover off of the injection pump and make sure the fuel shutoff shaft moves freely.
If it's stuck from sitting so long,it will cause excessive rpm's on startup.
Jeepsinker
446
Dry Creek, Louisiana
Runaway= window in block. X2 on pulling that cover and checking the movement of the shutoff lever. once you verify all is good there, pull the stop cable and keep it pulled while cranking the engine until it builds oil pressure, then push kill cable in and fire it up.
Hottrodd789
Orlando fl
Thank you I will make sure I check out the fuel shut off leaver out and have a block of wood to cover intake if needed.i was thinkn of pulling the valve covers off and doing a fresh oil change and pouring the new oil directly over the valve train just to lube it up some what do you think?
Recovry4x4
LLM/Member 785
1,807
GA Mountains
2 years is only a nap for a deuce. Light er up on the old oil then change it once it gets warm.
