Old mixed parts M35 Gasser VIN ID ?, please.
Davidwyby
244
CA
Old mixed parts M35 VIN ID ?, please.
So this is my old, abused, neglected, messed-with farm "water truck" deuce from my "Got a Deuce!" thread. Need to look into registering it. Tried CARNAC in '09, came back no such VIN.
EDIT: turns out it's an M35A1, not a mishmash.
DRIVER frame rail. Note lower number stamped over the OD green. Rebuild number or later civvy number?
PASSENGER frame rail. Number is upside down, but I flipped the pic to make it easier to read. The rails
middle 4 digits numbers match, then L(eft) and R(ight)
Axles are '62-'65-'67
Sprag Tcase - '60s, maybe
Trans is 3053A
'72 LDS-465
Generator/Delco Remy Regulator. Wiring is very old and dried/corroded/trashed. Cab looks very old and rusty (water truck...) Front sheetmetal looks to be Multifuel, bigger radiator, taller engine side covers.
Old style box seat
Multifuel style dash "on" switch, but non orig multi starter button. Mechanical (floor button/bellcrank) starter engage. Starter solenoid installed not original looking.
Lots of pics of everything....
http://s142.photobucket.com/user/DavidWhymore/library/DEUCE
Input much appreciated. Thanks!
@NoDakMark
Jeepsinker
470
Dry Creek, Louisiana
I think that M59520 is your number. Kind of looks like some rust from that patch above it may have ran down into the numbers when it got wet and stayed there. Doesn't necessarily mean that the numbers were re stamped or are in bare steel. Take a cotton swab and some cleaner and try and clean the numbers out, see if there is paint under the rust.
Either way, that is really the only number that could be right.
Davidwyby
244
CA
Sounds logical to me. Be nice to get some of the guys with old deuces to chime in. :)
Davidwyby
244
CA
Did I tick everyone off, or is the forum dead?
Went and looked at the neighbor's old gassers. They have a similar number to my short number.
rustystud
3,376
Woodinville, Washington
How large is your gauge panel ? The early deuces had a smaller panel by about 2" shorter. The starter floor button (bell crank) is also used on the early gas models like the "Studabaker REO" in the early 1950's.
Davidwyby
244
CA
I will compare gauge panel to my later model parts truck.
I think I have an ooooldie. The bell crank isn't electrical, it just engages the starter.
Thanks!
Jeepsinker
470
The dash may well have been swapped out though. It seems like whoever did the work sat the two trucks side by side and just transplanted enough parts to make everything work, quite possibly including the dash and cluster. I could probably tell you all you needed to know if I was there to look at it, but I'm over a thousand miles away... Much harder to do all this figuring over the internet and phone.
Davidwyby
244
CA
I was thinking the same thing, I could do some videos. Tour of the deuce and my donor.
I was adding up costs off the top of my head and I think by the time I replace all the rotted out rubber parts, electrical, and do all the brakes, tires, as well as repair the radiator, I could've bought another Deuce! But one piece at a time like Johnny Cash will get it there I guess.
Davidwyby
244
CA
Might get to go see Jack the green iron guru in Tucson tomorrow and look at all his stuff, I'm sure that will help. Maybe he will sell me a good truck minus engine.
Davidwyby
244
CA
To clarify, I didn't mean to sound snarky or demanding, and I wasn't referring to rusty or sinker :)
Just seems like there used to be a lot of guys around that knew a lot, and not much going on anymore...
Jeepsinker
470
Maybe they are just busy, or simply don't care to put any effort into the conversation. No telling. I can't say I blame them, there are plenty of threads I decline to post on because someone else will be along to say what I was going to say anyway, and I don't feel like explaining something. Us humans are inherently lazy ya know.
rustystud
3,376
So true. I almost never post on "HH" problems since there are plenty of people who will and there are a ton of posts already about it. Same with tires.
Eaglhawk
17
Grantsville, Utah
Actually I had an old gasser 2 1/2 ton that did not have a VIN # on the frame that we could find. After a week going over the frame with a fine tooth comb, we simply had the UHP submit a new VIN # made for it in Utah...
Eaglhawk
17
Grantsville, Utah
Also I have about 8 m35a1 gassers and a couple dozen m35a2's diesels. Now I have found from experience that some gas versions were converted to diesels and had various adaptor plates and sheet metal body parts made for the conversions. The older gassers did not have the tachometer in the guage cluster, the firewall is slightly different, motormounts different, (rebuilt diesel ones will have adaptor), front fenders different (or modified), etc...
Davidwyby
244
CA
Thank you, Eaglhawk! I think you and I have some of the same thing. I think it's kind of cool if a bit odd. Old REO style with 5 ton power, ha ha!
I have been an avid forum user for at least a decade, for whatever I'm into. I'm a member on more than I could think of or count, not that I use them all. I think this forum suffers from something I've noticed on a lot of them, forum burnout. Basically, all the info is already out there, and the guys who know are tired of answering noob questions and/or have moved on to other things. I understand, but it makes for a very noob unfriendly environment, and probably doesn't help the hobby. Sure a guy can search, but it's SO much faster and easier if people will give him a couple pointers. Course I am just as guilty of being selfish with my time as the next guy.
Davidwyby
244
CA
So, do you think I should run my 1100-20s dual or single? Ha ha Ha!
MWMULES
351
DESOTO, KANSAS
A lot of it has to do with there isn't a lot of folks on here that have M35 slick knowledge most gassers that are still rolling around are the M135/211. Oh and I run dual xl's 11.00 on my 35A2;-)
Davidwyby
244
CA
After talking to Jack and looking at his trucks, not sure, but it looks to be a USMC 1959 Studebaker that originally had an LDS 427 and was swapped to an LDS 465 (5 ton engine).
NDT
7,363
Camp Wood/LC, TX
Well Jeepsinker answered your question in post #2 and since I agreed with him I hit the "thanks" button rather than making a post that said the same thing.
