Kaiser67M715
- 26
- 18
- NH
So picked up my M35 Today,first pic is still at guys house, second pic is following tow truck home, third is truck parked in new home
well, I know the radiator is good, nice hiss of air when I opened it. so that should be fine, just need to fill with Coolant. Any recommendations? didn't see anything specified in the TM's, unless I just missed it.
second, gas tank is JUNK, inch of rust on the bottom, plus the way the paint is peeling under the tank, definitely a hole or two, there is actually more rust in the tank then the rest of the truck. Are these tanks the same as multi-fuel tanks?, or close enough to? or will I just have to make a new one?
third, wire harness is burnt to crisp. so need to put in a new one(included in purchase of truck).
fouth, brakes need to be gone through have no pedal, I am just hoping one of the rubber/metal lines went. Are the brakes the same as multi-fuels as well? I am assuming the only real differences is engine, wiring harness and probably fuel tank.
spare parts included with sale, wire harness(correct for GAS motor), extra drive shafts, axle shafts, budd nuts, and lug nuts, three 9.00R20 tire and wheel combos, new hub and drum. NOS master, and 2 NOS wheel cylinders, a bunch of TM's(specific to gas motor) and some other odds and ends
best part is it cost less then $1,600 for everything including tow
