- 34,012
- 1,813
- GA Mountains
What is gained by the double filament bulb? Is there a dual voltage double filament bulb?You can easily dis-assemble the Military lights and install a double filament bulb socket inside.
The double filament/double contact bulb ie 1157 is 12 volt and commonly used for stop/tail/turn lights: the idea was to make the original lights compatible with civilian/street use.What is gained by the double filament bulb? Is there a dual voltage double filament bulb?
No. He won't. I **** near forget my 103A3 is there. You can only see it while turning.You won't even see or feel it behind the 939.
