DavidWymore
- 164
- 63
- El Centro, CA
Yes, I'm hoping if someone has the same tag, we can figure out what the missing info was. I will email the mv tag guys.The Xs were probably for what the rods and mains were turned down to when it was rebuilt. That info is gone to as what box they were stamped in. I am almost 100% confident on that one.
Sir, you are correct on that. MCSC BAR was one of the old names which equaled Marine Corps Supply Center Barstow. It is the Marine Corps Logistics Base Barstow now. The new acronym they apply to rebuild tags is MDMC PPB which stands for Marine Depot Maintenance Command - Production Plant Barstow. Before current, it would be MCB or Maintenance Center Barstow and before that it would have been MCD BAR or Marine Corps Depot Barstow. If there is an A or ALB on the end of the acronym, then that is from the Depot in Albany, GA.MCSC BAR could be the equivalent to MCLB Barstow today. If that is in fact what it is, the engine went through there 3-72. MCLB is Marine Corps Logistics Base I believe!
