Hydraulic Head leaking need advice!
Floridianson
2,487
Interlachen Fl.
Don't know where your leak might be but when I work on one with any kind of HH leak I cut off the tin fireing order plate that just lays on top of the HH. Then it is so much esaer to see what and where. The plate is there for nonmechanical people.
Patruck
Athen, GA
I know exactly where the leak is coming from, I believe I know why, I just dont know how to repair or where to go to replace withou gettinp whole Injection Pump.
Floridianson
2,487
Interlachen Fl.
Correction,
There is a copper gasket underneath that hex head plug.
I cannot find the torque spec on it yet so I'd pull it clean it and reinstall and tighten....or better yet see if you can find a new copper gasket.....
No there is not a copper gasket or O ring on the top of the head hex plug. One on the delivery valve.
