Good Day SS
I need to see if we can refresh the Hydraulic Head conversation.
I purchased a truck from a Great guy In NJ fully understanding that there was a fuel leak at the HH the leak was not unmanageable. In an attempt to repair leak, a rubber oring was installed at the Fuel Delivery Bolt. The leak was hardly noticeable at high rmp. UNTIL.
The Fuel supply bolt had been over tightened at some point developing a crack or structurally weakening it after 300 miles it split and she sputtered and cut off. I noticed an alarming amount of fuel everywhere. Touched the FD screw and half of it fell off. Took a bit to get the other half out. Replaced screw with one that another Deucer brought me and it got me home still leaking exuberant amounts of fuel but ran long enough to get from NJ to GA. Now home I need to fix this problem.
Many i have talked with suggest that the HH will crack at that screw and cause a leak like mine.
Also herd that the screw can be replaced, the screw that is being used now is off a original HH so it is OLD. OLD, donor truck parked 38yrs.
So insight on this subject would be great.
Replace HH? If so, some direction to supplier would be nice.
Pump runs fine no sticking just leaking alot.
![Screenshot_2015-03-04-16-14-27.jpg Screenshot_2015-03-04-16-14-27.jpg](https://www.steelsoldiers.com/data/attachments/372/372077-f8b4547457c08aac80b6234d60a1922c.jpg)
![Screenshot_2015-03-04-18-58-44.jpg Screenshot_2015-03-04-18-58-44.jpg](https://www.steelsoldiers.com/data/attachments/372/372088-1346523d6e4cfb5699c8e4f795e9e970.jpg)
