goldneagle
- 931
- Slidell, LA
I want to install a separate battery bank for the 18,000 lb winch i am adding to my M923. I looked up the Installation instructions on one brand of battery isolators. There are 2 different types of the isolators. 1 has 3 large terminals only. The other also has an exciter terminal on it. Which type isolator should i use with the standard alternator that is on the M939 truck? Also what amp rated isolator do you recommend?
