Way to make truck not start so people cant drive off in deuce
Flyingvan911
158
Kansas City, MO
There are a number of ways. Search for Deuce Security in the search box. One of the easiaest ways is to put a locking switch inline with the battery cable. Most deuces have a chain that's welded to the driver's seat to wrap around the steering wheel. I also installed locking door handles on the cab.
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Open the bleeder valve on the top of the fuel filters on the side of the motor. Good luck figuring that out.
Also, pull the plug on the fuel pump in fuel tank.
CARNAC
The Envelope Please.
724
College Station, TX
Pull the batteries out. Cut the battery cable. Drain all the fuel. Drain all the oil (it'll start but won't run for long). Pull off the fuel lines. Drain the radiator (it'll start but won't run long). Remove the injector pump. Remove the engine. Use a 30-06 with armor piercing ammo to shoot through the engine block. Remove the turbo. Insert log into fan blade thus breaking pulley (it might start but again, won't run long). Use sledge hammer on engine. 1/4 charge of C4 in appropriate place should do the trick. Hope that helps.
m1010plowboy
2,985
Edmonton, Canada
Icecurety
If you read Steel Soldiers someone will always figure out how to get it running.
Just freeze them in a lake to keep them from being driven away.
dawico
Lampasas,TX
Whats a way you can make the deuce not start by turning it on in the cab?:?::?::tank:
I have seen where guys swap the battery switch with a keyed switch (on a 5 ton anyways, assume they are similiar). Or take the switch handles off.
Locking the steering wheel chain is the simplest way though.
5,176
C4 possession by civilians is frowned upon.
Valence
563
Davis County, UT
What, no one mentioned adding sugar in the fuel tank yet?
Besides the standard chain around the steering wheel, I personally opted for the non-destructive, non-permanent methods, such as: locking door handles (mostly just to prevent curious people with little social inhibitions from opening the doors to take a look at the truck and disengaging the park brake - some folks on here even fashioned a way to lock park brake handle), and a battery cut-off switch. I also put a lock on the battery door - not that it'll really stop much, then again, neither will the locking door handles with the gun-ring hole cut in the hard top or non-latching rear sliding window.
I'm of the opinion that adding a little more difficulty goes a long ways to making it "not worth it". Then again, I also don't think anyone would drive off with the truck but look more to steal smaller stuff inside the cab, tool boxes, or even fuel.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Removal of dogbone between batteries can make it hard, especially if you take it with you. There are several areas in the cab that can be interrupted with a hidden switch.
1,164
Or another thought is to trade it in for a CUCV and then you don't have to worry about it starting.
rofl Awesome.
You will find that pretty much 99.99998% of deuce related topics have been covered in great detail on the site. Spending a few hours getting acclimated with the search feature and learning how to use it will net you any information you want. If you need help, there's a link below in my signature line.
Here are a few links to get you started.
http://www.steelsoldiers.com/showthread.php?35963-Deuce-Security
http://www.steelsoldiers.com/showthread.php?30735-Deuce-Security
http://www.steelsoldiers.com/deuce-...ng/59694-self-locking-door-handles-deuce.html
http://www.steelsoldiers.com/deuce/59600-keyed-ignition.html
http://www.steelsoldiers.com/deuce-modification-hot-rodding/59568-keyed-ignition.html
http://www.steelsoldiers.com/deuce-...16728-anyone-interested-lock-kill-switch.html
http://www.steelsoldiers.com/deuce/4058-mv-security.html
http://www.steelsoldiers.com/deuce-modification-hot-rodding/47703-securing-locking-doors.html
http://www.steelsoldiers.com/deuce-modification-hot-rodding/7043-lock-up-security-deadbolt.html
http://www.steelsoldiers.com/showthread.php?126774-How-do-you-secure-your-Deuce
http://www.steelsoldiers.com/showthread.php?22478-M35A2-Security
Those threads will cover all the options you have. You can disable the electrical system, chain up the steering wheel and/or pedals, lock the parking brake, lock the doors, etc.
One day when I have the flu and can't move off the sofa, I am going to combine all those threads into one epic security thread so that all the info will be in one place.
He didn't ask about locking the truck, just how to keep it from starting.
I assume whenever I see a post like this that the OP is concerned about general security or theft.
porkysplace
1,496
mid- michigan
rofl Awesome.
But this is the day and age of instant answers.
CARNAC
724
College Station, TX
I was going to but then remembered it was a deuce. The a@#$%^&* down the street from me in GA tried that. It didn't work. Worked on my old camo CUCV I had but not on the deuce.
frank8003
4,990
Ft. Lauderdale, Florida
my favorite is to machine gun her
not allowed to do that now...........................
View attachment machine gun the Deuce.pdfView attachment TM-750-244-6_destroy her.pdf
