Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Does anyone know if the ABS ECU valve body can be serviced? I noticed mine leaking air out of the bottom port the other day when I walked past the rear of the truck after shutdown. I hope I can take it apart and find a seal/o ring leaking. Any info would be greatly appreciated.
Well I think I successfully fixed it. I removed the unit then separated and disassembled the valve body. All 4 o-rings looked fine except for grit that had accumulated over the life of the truck from the air lines and air system. After carefully cleaning everything and applying lube, it all went back together without a bit of trouble. The truck checks out fine without a hint of a leak. Now to tackle my drivers wiper motor.....
That's good to hear. And that's why your the master chief engineer.
I would never be able to get all the things done on my truck without you.
So I would like to say THANKS Andy and you are a great friend and I appreciate you.
