How to test this Niehoff alternator 570 amps 28VDC 76761-N1609 & -N3240 regulator
166
Hayes VA 23072
I could not find much info on this unit other than its one of the biggest ones they make. I have some water rights on an old hydro mill and would like to play with this a little bit. Does anyone have any wiring info on it? Thanks! It would be fun to find the optimum RPM range and see how well it would do charging a small battery bank.
Suprman
685
Stratford/Connecticut
Some of them will make power spun in either direction. Niehoff has a lot of info available on their site. You may have to look up the regulator separate from the alternator.
Recovry4x4
LLM/Member 785
1,807
GA Mountains
IIRC some of these were dual voltage and used on the HMMWV. Is there an NSN on it? Might could look for a TM on it!
Edit; NSN is 2920015669918 and was used on an MRAP. Single voltage unit.
