- 413
- 69
- 28
- Brookings, SD
Here is how I'm planning to add some stowage to my MM923. The case is a leftover from adding the battery relocation kit. I had a couple of ammo boxes so I picked up the rack to mount them. The last thing was the tow bar. I'm out of space on the truck where to store things and this is what I thought might work "well". I tried mounting the tool box under the bed near the rear axle, but could not make it work.
I'm looking for some critique before I drill any holes. I'll obviously swap out the wood 2x6 for c-channel steel. The set up does not interfere with the drop side and side loading.
Any thoughts? Good or bad...
Thanks,
Al Jones
Brookings, SD
Thanks,
Al Jones
Brookings, SD
