All big trucks and busses use these " jacking bolts" to help remove the drums. Even with the brakes backed off they can rust themselves to the lip of the hubs making it almost impossible to remove. The way the deuce is made though I don't believe this has ever been a problem. Even if it gets stuck, a good solid "whack" with your "BFH" can loosen it right up.I'm not sure what a "jacking bolt" is, to push the drum off the hub?
I've never had one not just fall off once the nuts and bearing came off!
If yours are not coming off, have you tried adjusting the brakes away from the drum?
I think so too. Probably why they just gave you a little inspection hole in the drum. It would be nice if a guy could get in there without going though all that work though, say if you just did bearings etc., and something wasn't right with the brakes.To answer the title question, it is this way likely to get troops to service the truck. Unlike road tractors, these are not oil bath bearings. As such, if it's time for the drums to come off, it's likely time to inspect and pack the bearings.
You sure about that?Ok, so what is that hub and drum off of? Mine doesn't come apart like that.
My deuce. All the pics I've seen look to have the same little bolts. The assembled one I posted above is from someone else's.Ok, so what is that hub and drum off of? Mine doesn't come apart like that.
It would make it hard to flip the hubs if they didn't come apart like that.You sure about that?
It's not an inspection cover per say. It's there so you can adjust your brakes with a feeler guage.I think so too. Probably why they just gave you a little inspection hole in the drum. It would be nice if a guy could get in there without going though all that work though, say if you just did bearings etc., and something wasn't right with the brakes.
DH, no, this is the farm-abused water truck that is still in the tear it down and put it all back together right stage.
Yours come apart the same way. Just most people don't take their drum off like that. I personally don't recommend it since you can't check the bearings this way. But it certainly is a different way of doing it.I've never taken mine apart that way. I've taken them completely down, and the drums look like that. Maybe it is just the angle of the pic and how it is layed out. Looks different.
I see now, the shield is still on it. Makes the hub look thicker. It is a front hub.
