Oldworldtenacity
- 0
- 16
- Charleston,WV
So, I had to bypass the lines when my air dryer valve got stuck open back FEB in 15 degree weather driving it back home from GA.
The low pressure indicator light would always flash and the buzzer would buzz and then once you bypass it it stops working...which I think is normal(although I could be wrong).
Anyways, got the new air dryer put on today and it works fine...however, the light and buzzer will still not work.
Any input as to what the problem may be?
