cev65
- 0
- 0
- Keyser, wv
Where can I find info on homemade pre oil systems??
You have a valid point there welldigger. With new style spin-on oil filters oil pressure builds right away.While a prelube system is neat, I honestly doubt anyone drives their duece enough to ever see the benefits. That includes you Jeepsinker lol.
I guess you'd have to ask a guy who broke a camshaft due to cam bearing worn out from dry starts.While a prelube system is neat, I honestly doubt anyone drives their deuce enough to ever see the benefits. That includes you Jeepsinker lol.
In this instance, isn't the answer to "not enough volume" ... just give it a little more time pumping?Nah, not enough volume to pressurize the deuce's oil galleys.
The problem is, your filling a passageway. If you don't have enough volume, you'll NEVER fill it.In this instance, isn't the answer to "not enough volume" ... just give it a little more time pumping?
Given enough time, I would think that any pump should be able to fill any container ... but I ain't a pump guy. I'm sure experts could fill in the blanks for me.
Don't think of it as a container, its a continuous loop.
Clear as mud?
Got a part number? It turns out that Johnson makes a bunch of pumps.Search "Johnson gear pump" they come in 12 or 24v and were meant to be used to suck oil out of boat engines to avoid spillage in sensitive environments. They come in a kit for around $120 bucks. No reason you couldn't plumb one in to work. I believe they build 30 psi, and use dot air line and npt fittings.
Please re-read my post #12. I never said volume "didn't matter" ... I asked if allowing a pre-pump to to pump for 8 seconds or even 10 seconds to fill all those passage-ways is better than a dry start-up. I cannot think of a single instant where running an engine for 8 seconds without oil pressure was a good idea.Think about how long it will take to fill the oil filter housings(how long does your stock oil pump take to make oil pressure?). Volume does matter. Pressure will not be achieved till the oil filters are fulled up and then goes to the small passageways.
