- 9,576
- 211
- 63
- Dickson,TN
It's been slow going on this project with work and kids getting in the way. The main goal now is to get the deuce bed where I can load and unload the shelter at home. That way I can work on it in the evenings.
I've got a HMMWV hyd winch coming that should be here tomorrow and I've got to fab up the tail roller. I'm going to make the tail roller removable so I can still used the stock tailgate when needed.
Here is my lame attempt at putting into drawings what is currently in my head. The first pic shows the winch mounting position and the cable routing. Green is the cargo bed, blue is the winch, red is the various rollers, and orange is the shelter.
In the second pic, Green is the bed, red is the tail roller, and orange is the brackets that will support the roller and allow it to be removable. The orange brackets will be welded to the bed side channel and to remove/install the roller I'll just slide it into the slot. The brackets will be welded far enough toward the edge of the bed to still allow the stock tailgate to function with the roller removed.
Anybody see any problems with this setup?
