Nhc250 ip vacuum/ fuel line rating
TechnoWeenie
1,797
Nova Laboratories, WA
Looking at replacing with rubberized line... Diesel rated..
From tank to filter, and filter to IP
The lines I'm looking at are gates 27006 which is rated at 35 psi and 10in/hg for vacuum and 1/2"
Couldn't find any spec on vacuum and didn't want to buy line just to find out it'll collapse under vacuum.
TechnoWeenie
1,797
The 27006 seems to be a low pressure evap/return line hose, but it's pretty well built, and it warns against using in pressurized fuel injected applications.
The hose you linked to is a different product...
Clarification?
