gottaluvit
- 26
- 48
- Bethesda, OH (AKA: Flyover Country)
Okay, now the horn. I looked all over the search function to find lots of posts on dueces but no breakdown for 5 tons. Traced my lack of horn to the wire in the shaft. Got 24v at the solenoid positive side. (wire 25) Unplugged the wire from the box at the bottom of the steering column and the solenoid clicks when I ground it. Checked for continuity from wire in column by horn button to the post on the box at the bottom of the column since solenoid don't click with horn button and no continuity. So I took the little box at the bottom of the column off and put one tester wire on the brass/copper that is part of the shaft and the other on the horn button wire and still no ciruit. Sound to me like that wire in the shaft is broke or unhooked. I have the column out and don't see how to take it apart to replace that wire.
Any help would be greatly appreciated.
Or a great deal on a full shaft with a good steering wheel and wire inside (working). My wheel is ALL cracked up and hideous so that might save another headache.
Thanks,
Jim
Thanks,
Jim
