RodUSMC1962
- 9
- 0
- Northwest, Indiana
George at White Owl.
That was my idea too... until I actually measured the bore depth: total = little over 3/8", cylindrical (inner) portion = 5/16", rest is chamfered. Which means there is no practical way to fit a second seal in there......gonna see if I can't fit two seals on the shaft and box, one for dust, the other for the oil....
Check this first post for inexpensive DOT 5I know DOT 5 is recommended, I have seen some for sale on Ebay, and through the surplus dealers, but a gallon runs close to $75 or more...any other places I could check? Want at least 2 gallons
just did some measuring myself, with two seals, the second seal would only be in halfway(not including chamfer portion), so maybe with some RTV, but probably notThat was my idea too... until I actually measured the bore depth: total = little over 3/8", cylindrical (inner) portion = 5/16", rest is chamfered. Which means there is no practical way to fit a second seal in there.
G.
Thanks, must have missed that, read that thread a few times to get dimensions and reading up on the Cunifer Line(which I am forgoing this time due to money and the fact I only need to replace a 28 inch section.Check this first post for inexpensive DOT 5
http://www.steelsoldiers.com/showth...hs-fittings)&p=1539040&viewfull=1#post1539040
