Check withWell yea makes a great ground shop. I have one on the ground powered up with 110v, tools and parts cleaner tank.Does anyone know what the van box its self is worth is there any good uses for them without the truck
Dan I'm thinking about pulling mine and putting in a small pot belly stove, or propane heater. AC is less important here than heat for hunting season and want to run sans generator only pure solar. Any issues cutting through the top or walls?We have pulled about 3 Ac units out of expandos and they are sitting in our shop. Most look brand new. $100 each (you must pick up or arrange shipping, they weigh about 300lbs and thus the reason I am charging $100. To pay for my medical bills)
I put single phase 10,000 btu Ac units in and cut a piece of foam core paneling from Home Depot to go in the open flap up front and top, and then cut out the right hole size for the smaller Ac unit to fit through and make a good thermal seal. When its time to pack up, pull the Ac, pull the foam core, shut the flap, and away you go. Works pretty good as long as you are not parked in the heat all day in dark green Camo. (White paint on the roof drops the heat inside the box TREMENDOUSLY. ) so does cracking the windows a hair. If you rewire the breaker panel to work off a normal generator like a honda 1000, those Ac units will run and just plug in to any of the roof plugs or the front wall plugs. Pretty slick. I spent three days in 103 degree heat last week for a family reunion. Ac worked great until about 3pm. Then the dark green roof finally overpowered the Ac cooling and started to heat up the top foot of the inside of the box pretty good. Tan trucks don't get quite as hot.
Greetings, I have been looking for a long time for a post such as this that covers the challenges of attempting to dry in an expando van. I have replaced the long P shaped seals as you mentioned above, however I am currently dead in the water attempting to find any of the other weather stripping needed to complete my restore. Specifically the weather stripping located on the most outer wall shaped as such. ( ID ) It is the stripping that has the metal backing strip that goes inside the stripping itself to mount. If you could shed some light onto me as to where and how you obtained that weather stripping, with links, other posts, or other methods, It would be appreciated.If the van still has the fuel heaters, then the asbestos mod has not been done. When the asbestos removal op was done, the AC was replaced by a heat/AC combo unit. They actually didn't remove the asbestos. They just sealed up the fuel heater vents that contained it. These are all in the front wall of the van. So just as note to anyone replacing panels and stuff in these things, the asbestos is still in ALL of them.
I have seen the heat/AC units on eBay from time to time. Mine came with one it in and it is fully functional. As to fitment, there isn't much. They just sit the unit on the shelf and that is about it. Big air gaps around the bonnet window. Some had sheet metal to force air through the roof panels and some didn't. The original AC unit that was paired with the fuel heaters might have been fitted better.
As to the value of the van body by itself? Hard to tell. They are not water tight when expanded, by design. It is a temporary and mobile shelter that will do the intended job of keeping equipment and personnel shielded from the weather, but water will invade and run down the front and rear fold out panels. They are only water tight when the sides are in and then only if the seals are in good shape (most are not). So, IMHO, the van bodies would not work well as a storage container. A 20 ft. shipping container would work far better.
I just recently re-paneled my expando van. The interior side panels were rotted due to improper stowage and bad seals. The main seal in question is the long P shaped seal that runs the length of the van body at the top where the sides slide in. It was a solid extrusion. Meaning that it had no air pocket in the P. This seal melted for some reason and made a complete mess. It is hard to tell if it melted because of a chemical reaction or just from baking in the sun. Regardless of the cause of the melting, the seal was not functional.
Upon ripping out the rotted panels, it became apparent that a LOT of work had to be done. All of the insulation had to be taken out and the steel framework of the side walls had to be wire brushed to remove rust and scale. Another nice design feature is that they did not put any drain holes in the side panels. So if water got in, it never got out. When I removed the lower panels, there was about 4 inches of water in there. No telling how long it had been there. Luckily, the steel structure had been painted when it was built. So the structure was still strong and the rust had not become cancerous yet. But brushing and getting in all of the cracks and crevices was a lot of work. I installed drain holes in opportune places and re-painted the steel structure with rustoleum before re-installing new panels. New seals were also put in place. It should be good to go for another 30 years now.
So that is about what it takes to get one dry. http://www.steelsoldiers.com/showth...on-this-week&p=1721871&viewfull=1#post1721871
.Greetings, I have been looking for a long time for a post such as this that covers the challenges of attempting to dry in an expando van. I have replaced the long P shaped seals as you mentioned above, however I am currently dead in the water attempting to find any of the other weather stripping needed to complete my restore. Specifically the weather stripping located on the most outer wall shaped as such. ( ID ) It is the stripping that has the metal backing strip that goes inside the stripping itself to mount. If you could shed some light onto me as to where and how you obtained that weather stripping, with links, other posts, or other methods, It would be appreciated.
Also you mentioned you re-installed new panels. Knowing that when box was expanded there is still a chance of water coming through, what type of material did you use for the panels? Ive been considering a poly marlite panel and I thought id get your take on that as well. Thanks again.
