New Intake
rustystud
3,317
Woodinville, Washington
073.jpg074.jpg076.jpg Here's some pictures of my new Donaldson "Topspin" pre-cleaner. It seems to be a pretty good unit. The side of the housing has a slot (seen in picture 2 ) at the top and when driving air is forced in causing an impeller to spin. This spinning forces the large particles of dirt and dust to fling outward and then drop out the bottom of the housing. I've noticed the impeller also spins just from the intake of air from the engine running. We will see if this keeps the main air filter cleaner like they claim it does. For those wondering about the tarp over the cab. I have a soft top so to protect it and keep it from leaking I tarp it over whenever I'm not running it.
HanksDeuce
263
Prairieville, LA
If I could provide a minor correction to your post above. It looks as though the topspin takes air in from the bottom perimeter, and as the impeller blades in the top of the housing spin the dust/dirt particles are accelerated and shot out of the 2 slots in the sides of the housing. How much is this Intake?
Here is a YouTube video of the Topspin in action:
https://www.youtube.com/watch?v=QwfYnsRbveg
jbayer
10
St. Aug., FL/ McGrady, NC
So does that mean the slot should face back, and not forward?
rustystud
3,317
Yes I think your right Hank. The directions that came with it where rather vague. I haven't seen this video either. I guess I have to rotate the housing to point the slot back towards the truck. The directions said you needed to keep the slot clear for air movement. I ASSumed it meant to allow air in not out.
montaillou
846
W.WA
Just now came across this thread and being as it's been 2+ years, how do you think the performance of the pre-cleaner has been to the life expectancy of the air filter?
rustystud
3,317
It helped a whole lot. Since then I replaced the whole filter to an A3 style for more room in the engine compartment. That style has it's own "pre" filter on it.
