Oldworldtenacity
- 0
- 16
- Charleston,WV
Ok, So I probably put about a 100 miles on my truck since yesterday and finally my luck ran out and I encountered another issue. Luckily I was close to a good place to park the truck not far from home.
Truck was building air fine for about an hour driving around today and all of a sudden my low air pressure warning buzzer comes on and I only have about 60PSI in both tanks. I had just enough Air to get it parked basically.
To make a long story short, fellow local member Sharkbait was nice enough to come and help troubleshoot the problem. He even had a new Governor and put one on in case that was the issue. It wasn't unfortunately.
Finally we just had to charge the system with air from his truck which was enough to get me back to my place driving slow.
Just put a new Air dryer put on about a month ago and couldn't find anything wrong with it or Expello valve. The Compressor is also working...although cant tell how good though.
Also, there are no hissing or obvious leaks anywhere. The truck just won't build past 30-40 PSI after draining tanks empty...it is also verrrrry slow building to 30-40 PSI as well...then it stops....sometimes makes it to 40..other times just 30. Strange.
Totally puzzled here.
Has anyone else had this problem or know the best way to continue troubleshooting?
