turbinesurgun
- 4
- 8
- Lumberton Mississippi
Does anyone make a plug to go from the big military light plug to civilian style? I know the 24-12 volt issue just wondering
That is correct, everything should be a plug and play for you.Thanks much. So if I'm looking correctly I don't even have to worry about the 24v on the mil vehicle bc this box will step it down to 12?
Just catching up, looks like you found the correct adapter, hope it works out.No sir, I should have been more clear. The trailer connector plug. I have bought a 932a2 that I plan on hauling tractors and hay on a step deck with.
What are you trying to say with "bc" as far as I know there is no word spelled bc.Thanks much. So if I'm looking correctly I don't even have to worry about the 24v on the mil vehicle bc this box will step it down to 12?
