RustyM923
- 7
- 18
- California
1993 m998 with a rebuild in '07. Engine is a GEP 6.5.
Temp shows 240 (after a proper warm up.) Fan comes on. Less than a minute later, the fan shuts off. Then about 2 minutes or 3 minutes later, the fan comes on again. Tsu for fan seems to be sensing the heat and also the cooldown from the fan cycle.
Coolant flushed. Small hoses and coolant tank nipples clean and clear. Running straight water until resolved.
Grounds are good, harness appears unmolested. TDM unplug sets fan on...clutch working as it should.
New 6.5 specific t-stat ( looked identical to the one that came out, had the same jiggler valves in it, also tested on the stove top, both were open when water was boiling)
I checked the temps with non- contact therometer....results:
Cap off....Coolant tank about 188 to 197. Radiator hottest part (drivers top), 200 to 205. No boilover with straight water and cap is off...no pressure.
Changed temp sending sensor to a new one (that was fun). Now reads 235 to 240. Fan coming on does not indicate a temp drop of more than a few degrees (hard to tell).
The gauge looks brand new (no over spray from 07 repaint, no scratches. ..definitely new).
Next step, a new gauge.
Anything else I'm missing?
(I've read the TM and the relevant portions of the 280-20.)
