Thanks for all the tips. The batteries seem to be working fine.
I could not find the braking fluid to check it.
I am not 100% sure I found the fuel filters but I think so. I didn't change them.
I changed the engine oil. It was bad. A ton of decent size metal in there. Changed the oil filters as well. I checked the dipstick before changing the oil. It said it was only 4 qts low. Only 2 gallons of oil came out. I found this very strange. It took 5.5 gallons to fill it back up which is normal. Weird.
I changed the transmission oil, it looked new.
I drove it around the block. Thing practically dies when I shift to 4th gear. I wonder if I need to let it get going a little faster before I try that.
It seems impossible to take off in 1st gear. By the time I shift to 2nd, it stops... Haha. I've been taking off in 2nd gear. Seems to be doing alright that way.
The engine makes a really loud clanking noise while idling. Sounds like the broken rocker on my car when it went out. The sound goes away when you simply push in the clutch, or rev the engine. Anyone know what this might be?
I got the gauges to work. Everything but the temp and RPM seems functional. I've included a picture of the gauges while idling after the oil change. Air pressure looks low but I think everything else is alright.
All that work aside, she sure is fun to drive! Drove around a residential neighborhood. This thing dont turn on a dime... or a quarter for that matter...
