zout
- 154
- 63
- Columbus Georgia
Got floor plates getting to be installed - only one left to fit is the beat to **** center hump plate that covers the valve cover. Someone smashed the chit out out of this cover - it should fit tight on an arch from front to back - NO WAY this baby fits the way it is and you can see the huge gap that exists.
Problem one - IT HAS AN ASBESTOS INNER LINER LIKE THE TWO OUTSIDE COVERS - SEE THE SECTION OF THIS KILL.
So the center section needs to be handled correctly - then reform the arch to make it fit. Everything is not as easy as it looks fellas.
Got the throttle plate in - its return spring set up correctly with great movement so PB can feel like he is hammer down headed down the road.
Got the coil remounted as well - where the stock mount is was alongside the head - fitted there it stuck above the floor plates - so it was moved properly.
You can see where I am headed moving into the weekend - so just hang in there.![20150902_160828.jpg 20150902_160828.jpg](https://www.steelsoldiers.com/data/attachments/395/395552-f66da63725e0ccd6cdc5fa56f3a9ac8d.jpg)
![20150902_161023.jpg 20150902_161023.jpg](https://www.steelsoldiers.com/data/attachments/395/395553-cf5108c48c21bb9bc6b9957d5b8d6d73.jpg)
![20150902_161112.jpg 20150902_161112.jpg](https://www.steelsoldiers.com/data/attachments/395/395554-f8e46310b66c266ffb449308eabd316d.jpg)
![20150902_161848.jpg 20150902_161848.jpg](https://www.steelsoldiers.com/data/attachments/395/395555-1f331c78058383497544b22443d8886d.jpg)
![20150902_163356.jpg 20150902_163356.jpg](https://www.steelsoldiers.com/data/attachments/395/395556-b8e7a404dd1ce488722b96edcaf4a518.jpg)
![20150902_170224.jpg 20150902_170224.jpg](https://www.steelsoldiers.com/data/attachments/395/395557-1f62ac1d9684abbf039d39ae725faad3.jpg)
![20150903_155237.jpg 20150903_155237.jpg](https://www.steelsoldiers.com/data/attachments/395/395558-38c56e9f471dcd9207aa21997bff4fae.jpg)
![20150903_155337.jpg 20150903_155337.jpg](https://www.steelsoldiers.com/data/attachments/395/395559-76881965e698a7ca6d70e60e704700e5.jpg)
![20150903_155702.jpg 20150903_155702.jpg](https://www.steelsoldiers.com/data/attachments/395/395561-59bfd0fb5109b5a641c911b9b828f423.jpg)
