peashooter
- 205
- 63
- Hanover, minnesota
That all looks fantastic! I've never seen that type of differential breather kit before, cool. I also love those braded hoses under the hood.... Very well done!
It's great when a problem has a relatively easy solution (because sometimes they don't).Ultimately I could but to me it would put undue stress on the hose. So solution....use a 1-2" extender on the primary filter outlet and move fitting where the hose attaches forward slightly.
I'll be putting it together later today. Then I'll post pics of it as well as measurements. I figure with the measurements if anyone else likes the way the hose is run and wants to copy it they can.It's great when a problem has a relatively easy solution (because sometimes they don't).![]()
I forgot to mention earlier that I remember someone's thread from a year or 2 ago about a member getting new injector lines and finding out that several of them had obstructions within the brand new lines. So make sure to check them before mounting them.Brake lines will be here tomorrow as well as my new injector lines.
Talk about your nightmares, that would be one of them right there; what a PIA.I forgot to mention earlier that I remember someone's thread from a year or 2 ago about a member getting new injector lines and finding out that several of them had obstructions within the brand new lines. So make sure to check them before mounting them.
Yes that swoosh is the airpack venting as the internal air assist ram travels back to "home" positionSo far no leaks, everything is dry. Something that is interesting...I get a subtle swoosh sound of air release when I let off the brake pedal. Never used to have that. Is that normal? If so....maybe my airpack issues have been brewing for a long time.
Took a bunch of pictures and will upload those later.
peashooter, you know more about the "Art" of the Deuce than d*** near any human being alive I believe (I mean you, and the select few others who regularly chime in here so helpfully).Yes that swoosh is the airpack venting as the internal air assist ram travels back to "home" position
