MississippiRifle
- 18
- 18
- Poplarville, MS
Moot point sold the 932.
M35A2-AZ do you have the part number for that valve?Here are some pics of the old spool and the new two stool I installed. I still need the winch control cable.
Yes I would like you would need a little big tank then the one on the M932. The one on my m929 hold about 6.5 gals of HD.
Actually not moot. I have thought about it and I'm sure many others too.Moot point sold the 932.
Here is the one I used, Long story LOL, There are others that may cost less.M35A2-AZ do you have the part number for that valve?
What will work better for you...pics or videoI need pics from underneath the truck showing the hyds. and controls.Also does a m930 use the oil tank on the dump body for the winch ? thanks,john
Yes the m930 uses the same oil tank that the dump uses.I need pics from underneath the truck showing the hyds. and controls.Also does a m930 use the oil tank on the dump body for the winch ? thanks,john
Not sure if you still have the truck, or use the winch much or not, but do you notice or know of any ill affects of not using a motor spool for the winch?Here is the one I used, Long story LOL, There are others that may cost less.
The things you need are open center, spring centered, (DA) double acting. Surplus Center 9-20-2-X
I did not use a spool that is for a motor.
http://www.surpluscenter.com/Hydrau...S-PRINCE-STACK-VALVE-OPEN-CENTER-9-20-2-X.axd
I have not seen a problem with it, I have used the winch three or four time.Not sure if you still have the truck, or use the winch much or not, but do you notice or know of any ill affects of not using a motor spool for the winch?
The only thing I can think of would be a shock load possibility, when stoping winching out a heavy load, such as using an A-frame setup for lifting?
