lonewolf90
- 0
- 0
- Michigan
I doing a nv4500 swap in my m1008 and was wondering if I would be able to do freeway driving 70mph after I get it in. The truck is completely stock.
It only works in two wheel drive.What's wrong with a Gear Vendors Overdrive? It's the most plug and play solution for your application. And you don't need to add a clutch pedal and cut a new hole in the floor. They claim a 22-28% increase in mileage. Obviously this is just a suggestion. Here's a link to their webpage: https://www.gearvendors.com/4x4gm3s.html
I would not call a 27% reduction in rpms at speed, be it 60 or 70 mph a small gain in economy/mpg. OD transmissions weren't made to increase top speed but to increase economy of motor.A GV OD loses out in the torque converter slip. Best is manual OD. 4L80E offers lockup torque converter but there still is a good bit of loss off the pump.
you only gain a trifle economy by going to a lower cruise engine speed. Overdrive just lets you go faster where drag increases as the square of speed.
It depends on how you look at it.I would not call a 27% reduction in rpms at speed, be it 60 or 70 mph a small gain in economy/mpg. OD transmissions weren't made to increase top speed but to increase economy of motor.
