74M35A2
- 339
- 83
- Livonia, MI
Brought home a DC load bank and clamp on DC ammeter this weekend to measure the output of a stock military 60A alternator. Ambient air was 47F, and the measurements were done with the engine and alternator cold. Output will be lower as alternator warms. Measurements were done with calibrated equipment which was zeroed, on an M925A2 (Cummins 8.3), at engine speeds of 600rpm and 1500rpm. I used an external load bank to load the alternator until output saturated and would not increase any further. As reference, alternator output just after engine cold start was 4.6A, which is made up of both the current to hold the shut off solenoid open, and battery recharge. The 8.3L typically starts with just a mere bump of the starter switch, much less than 1 second of cranking. I am running twin group 31's for batteries.
Idle (max): 69.6 amps
1500rpm (max): 91.3 amps
