Windshield Wiper Power Loss
Vexiis
California
I have a very odd problem I haven't been able to isolate, so I figured I would ask here. I have a radio running to the fuse box at the fuse labeled "LPS" just to the left of fuse #6 from this post. http://www.steelsoldiers.com/showthread.php?132309-CUCV-Fuse-Box-Layout I have also tested it in the three 12v ports controlled by fuse 15 when the truck is on. The power works fine in both places, however as soon as I turn on my windshield wipers I lose power to the radio, everything else on the truck works fine. The windshield wipers are very slow so I think I may need to replace the motor but it still works.
Any ideas of why the radio would lose power? It happens regardless of which fuse it is connected to.
Mainsail
1,800
Puget Sound, WA
Radio? That's a little vague don't you think? CB radio? Ham radio? AM/FM radio? Military radio?
You should always wire a two-way radio directly to the battery. If you want on-off with the ignition, wire a relay through the wiper fuse- it's the only one that's ON in the RUN and ACC positions.
For an AM/FM radio, I would do the same as above with the ignition control through a relay.
Vexiis
California
Sorry, it is a AM/FM radio. Ok I'll have to look into wiring it directly with a relay from the wiper fuse. I just found it strange it turns off when the wipers are on (regardless of which fuse it is connected through).
dependable
188
Tisbury, Massachusetts
If the wiper motor is on its way out,(like armature/winding short) it could draw enough amps to affect the whole system. Replacing or testing the wiper motor is a good start.
The fuel heater circuit is off the wiper fuse also, another thing to check if there is a short.
