rustystud
- 3,259
- Woodinville, Washington
No, it's going in the bed along with the other equipment. I will run an exhaust tube out the side. This way it will be quieter and out of the elements and out from prying hands !Nice trailer. Are you going to try and place the genny on the tongue?
I really like this idea and I was looking to see if I could perhaps do similar with my larger Goodyear G177s.
So a number of questions there rustystud if you don't mind!
It appears that you modified how the front of your cargobox attaches to the frame. I have this spring assembly on my M105:
- If you did modify how the cargo box attaches to the frame, could you please provide any further insight? Was it to fit the tire hoist or other reasons?
- Do you think drilling the large holes on the side of one of the trailer frame members (to access the bolt nuts) causes any substantial weakening of the trailer?
- How far from the edge of the trailer box is the spare tire hoist's hex head crank point?
- What is the clearance between the spare tire and the tire on the axle?
- What is the distance between the spare tire's sidewall and the trailer frame?
- What is the distance between the spare tire's sidewall and the ground?
- How far past the edge of the cargo box does the t
I will have to get out and measure everything for you tomorrow.
That's correct Piper Cub. My trailer is a 1986 model.Valence, I "think" that that's just a difference from the older trailers to the newer ones on how the bed mounts. From a quick look on GP it's hard to tell for sure though.
No rush, but it is much appreciated!I will have to get out and measure everything for you tomorrow.
The tires have over 18" of clearance, so if your hitting things that are 16" tall then yes you will hit the tires. You also realize the axle tube is only about 12" off the ground.The idea of the spares being mounted on the trailer isn't new. That is a likely place but I have always hesitated, as it doesn't take much of a hump there, to high center that tire. I'm not talking serious "off roading" but a shoulder berm on a roadside would cause problems. Put just a little load in that trailer and your spare will be two inches closer to the ground when your overloads are in contact with their hangers.
I thought to cut the winch part off the mounting bracket, and get that tire mounted up next to the bed. Mount the winch part on the outside of the box & route the cable via a couple of small pulleys. On the bolster trailer, the two retaining nuts have to be accessed from underneath - not as handy, but usually they are seldom used.
The pry bar mount was the first thing I installed ! After almost 40 years working on heavy equipment I picked up a thing or two about using leverage to help you. Also working the last 24 years on swing-shift it is hard going to bed any earlier then 12:00 midnight. Usually it is 1:30am or 2:00am before I go to bed. Then I get up at 7:00am to take the boy to school.I can relate Rustystud. Just manhandling the rims around on the 9.00-20's is getting to be a chore. With tires, from flat on the ground, it takes me a lot to get them vertical so that I can roll them around. That long prybar can be very handy. I guess your a late night owl too.
