Hydraulic overprint???
engele
Nagold / Germany
Hey guys, i saw hyfraulic Fluid next my spear tire. I thinked this Reservoir was for The chemical detector which was installed.
I'm at The Highway with my Truck to pick up my new Shelter and have no tm with me.
Thanks a lot
NDT
7,533
Camp Wood/LC, TX
The part that is leaking is your hydraulic power pack which raises the cab. You will need to overhaul it. Parts have to be ordered. There is a thread here on how to do it.
Lmtv772
Banned
651
19
Florida
It also looks to me like the hydraulic latch is leaking.
There also should be a cover on the hydraulic power pack. Did you remove that?
Suprman
707
Stratford/Connecticut
Sometimes the hydraulic fluid feed and return lines come loose and it will leak from there. Hard to get to unless you take the metal housing cover off though. They are left side forward on the pump.
Lmtv772
Banned
651
19
Florida
I think he's got the cover off already
They are 9/16 if you want to check whether the fittings are tight
