Where to get Tie Rod End Socket Seals?
jpg
15
Boston, MA
The TM says I should replace the rubber "tie-rod socket seals" on my tie rod ends while I have them apart for installation of new kingpin springs. I can't find anyone who sells the seals. I can see that the seal comes in the box if I buy a new tie rod. Where can I get the seals?
I just spend half an hour searching. I must be using the wrong search terms... I looked on SS, Summit, RockAuto, LMC, etc... I can find new tie rod ends that come with new seals, but not the seals alone.
Thanks!
Chaski
56
Burney/CA
I am not positive about this, but I think with the steering wheel unlocked and with the vehicle supported with the wheels off you can actually manipulate the drag link and the arm that bolts to the top of the knuckle over the studs without taking any of the ball joints off. With 100% certainty I know the job can be done without messing with the ball joints if you double nut the studs and unscrew them. The thread is 1/2*20 if you want to buy some nuts beforehand so that you don't risk damaging the stock tapered nuts.
fitz
13
Mass
While I hate to second guess the TM's I didn't remove my tie rods or drag link to replace my springs & bushings.
jpg
15
Boston, MA
Thanks guys. I'll use the double-nut approach and pull the studs.
Update: The double-nut approach worked like a charm. It's a bit tedious, but I didn't damage my hard-to-replace tie rod end seals.
I still need to replace the 30-year-old rubber boots, they're failing due to age, but that's another project.
fitz
13
Mass
There is no need to pull the studs. With a little wiggling, the steering arm will lift off.
jpg
15
Boston, MA
Mine was too tight to do that. Perhaps it would have worked if I'd used more force, but I have a long history of breaking things when I use too much force.
jpg
15
Boston, MA
Yes, driver side installation went well. Passenger side tomorrow.
I used the double nut trick to remove and install the studs. I couldn't find a torque spec for the studs, so I used the same as the nuts (80 lbs). Does anyone know the proper torque for the Kingpin Cap Studs? #21 in this excerpt from Fig 101 in TM9-2320-289-34P.
Bushings were OK. I installed the urethane block instead of a spring, hoping to kill the death wobble forever. We'll see...
(ORD has these.)
doghead
4 Star General /Moderator
1,176
A while back someone posted a WTB ad for the tie rod end boots.
Dorman makes them, iirc.
They were only a couple bucks.
