Woodsplinter
- 6
- 18
- Phoenix/AZ
How to set the idle speed on the LDT-465. This will be a refresher for some and new info for others.
The idle adjustment screw is located on the side of the injection pump, below the FDC if so equipped. It is held in place by a 7/16" jam nut.
Loosen the jam nut by turning it to the left (counter-clockwise) about half a turn.
While holding the jam nut, turn the adjustment screw to the right (clockwise) to increase idle speed. The process is easier if you do this with the engine running- have soldier "B" monitor the tachometer or go check it yourself until you reach the desired RPM.
While holding the adjustment screw with your screwdriver, tighten the jam nut and you're finished!
Mine was originally set at about 500 RPM and I set it at 800 RPM so the truck doesn't shake itself to pieces. Nice and smooth now!
Hope this helps!
Hope this helps!
