Can Hummer H2 wheels be mounted on hmmwv m998?
orgnal
Denver, CO
Can hummer h2 17 inch - 8 bolt pattern alloy wheels be mounted on HMMWV m998 ? Looks like the bolt pattern is the same. Thanks in advance.
5,206
Pattern is the same, wheel thickness (for studs) is much thicker on the H2's. And the backspacing is all off/wrong. It might work, but it won't be right.
KansasBobcat
9
San Antonio, TX
With all the cheap, real HMMWV wheels and tires available why would you want to do this. Just asking...$175.00 for new radials with runflats seems like a bargain to me. I'm not selling them so just curious.
my69camaro
La Porte Indiana
Yes they work, you must machine out the centers ever so slightly. They stick out slightly more so you must be mindful of body contact. Upside is they are cheap, weigh much less and open up a larger portion of tire availability being they are 17in rims.
joelowe
Oregon
Stevepsc
Conway, SC
I have 8 almost new goodyear oz mounted on 12 bolt rims I am looking to get rid of. PM me if interested. These tires are so new they have the little rubber feelers on them. One set came with my 1038 from gp and the rims are black. I bought the other set from Demil facility in Wilmington NC and are on tan rims. I bought a set of the new Kevlar walled goodyears from the same place on 24 bolt rims. So I have way too many tires.
Jonesy
Port Washington, WI
I'm considering it. Or just finding replacement wheels in general.
The runflat wobble is the bane of my existence.
Going to try the centramatic wheel balancers, and then I'm gonna be shopping for new wheels if that doesn't work.
richingalveston
122
galveston/Texas
get rid of the run flats and keep the hummer rims and tires. use pvc sleeves so you still get double bead lock. run flats are useless unless you are actually going into combat. They will ruin any tire if you run on them very long.
centramatics probably wont fix it completely, will help but it is really a mask to the problem.
I have centramatics and love them but I don't think they will completely fix your problem. the run flats are just to heavy and normally way out of balance for a street rig. I know they make them for H2 but not sure about HMMWV. below are the centramatics for the dana 60.
Jonesy
Port Washington, WI
I'm of two minds on the subject of keeping the runflats.
I'm not in combat, but I do use the truck for airsoft events, forty hour scenarios and what not. More than once now I've been saved by the runflats after picking up screws, a discarded ammunition casing, and once- a very gnarly thorn.
On the other hand, road performance is less than stellar, and just today I found a weird bald spot on my right rear that I believe is a result of the poor balance.
Realistically, I should run the runflats for events, and a set without for the days and weeks in between.
Thanks for the tips on the centramatics. I'm not expectimg them to be a magic bullet, but it's nice to know they'll do SOMETHING.
fllaw1
St Augustine, Forida
My 2 cents, I have both vehicles and I think the H2 wheels look more rugged without the center caps on. I would never put them on a Humvee. I like the wheels Arnold has on his here in the photo. Arnold.JPG
