How do you bolt radio antenna mounts to truck?
nyvram
Franklin/TN
Is there a special bolt or tool needed for this? I see the holes on the vehicle but not sure if there is a 'molly bolt' type solution here or something else.
Sorry for the dumb question..just can't quite figure this out by reading the TMs.
Also where do you find the correct bolts and what size?
We picked up a interior radio mount, I'm looking for the screw/bolt size for that as well.
Thanks!
nyvram
Franklin/TN
here's a pic of the holes on the body for the antenna mount in the drivers side closest to tailgate. i'm not sure what to make of those..are you saying those are actually threaded already?
we just need to find the correct bolt/screw/washer (and maybe some of your gasket maker to seal it proper?)
here are the holes on the drivers side closest to cab. as you can see there's some kind of aftermarket antenna mount abomination on there now we will be removing and replacing with both the mount + the guard to help hide any additional holes cut into the metal (hopefully)
the WORST spot by far is the passenger side closest to the cab. it looks like the mount was ripped off completely and new holes were cut..for whatever reason. we're still not entirely sure what to do about this side. the door still closes perfectly even with the dent. at a minimum we are going to sand and fill in the holes to keep water out and further rust developing.
if you look closely, there's still a bolt attached to one of the 4 original holes we will need to dremel off.
Sharecropper
1,110
Paris KY
You need 1/4"-20 Heavy Duty Rivet Nuts from McMaster Carr. http://www.mcmaster.com/#catalog/121/3306/=zgujfw
Don't buy the aluminum - get the Zinc Chromate plated steel ones 95105A143 for $9.08 for a pack of 25. You will also need a sharp 25/64 drill and a tool to install the rivet nut. McMaster sells the tool for $30 http://www.mcmaster.com/#catalog/121/3309/=zgun2q but a lot of guys make their own. Basically you position the antennae mount where you want it, mark the holes with a Sharpie, then drill the 25/64 holes. The rivet nuts are sort of giant pop rivets but threaded on the inside. When they are crimped into the drilled hole, they provide a 14"-20 threaded socket to run the bolts into. Kinda neat, really.
Hope this helps.
nyvram
Franklin/TN
i dont want to add new holes. if you look at the pics i've posted it appears there might be nuts already there for some of the mounts. one side (where the truck is dented) definitely does not have anything..just holes.
alpine44
21
Asheville, NC - Elkton, MD
The holes in the metal need to be the exact size for the rivnuts to clamp securely to the metal.
I would repair the dented area with a sheet metal patch and then drill the correct hole size for the rivnuts in the original location.
TGP (IL)
36
Metro East IL
I don't think those holes were ever threaded or had nutserts in them from the factory.
Maybe a depot or field repair?
A plate was made up with two nutserts in it and held on the inside of the outer bed wall or fender while bolts were passed through the ant.
Bracket and threaded into.
Two plates per mount.
At least that's how it was on the couple I removed.
Tom
nyvram
Franklin/TN
i saw a thread about those plates. i dont disagree but those holes appear to be in the correct place on the passenger side, just got ripped out maybe.
we are trying to restore the vehicle as close to how it was originally so we don't want to add any guards or antenna brackets that weren't there originally.
there appear to be 3 sets of '4 bolt pattern' holes (driver cab, driver tailgate, passenger cab) and the passenger tailgate just has one hole..maybe for a tie-down clip?
tim292stro
40
S.F. Bay Area/California
Rivnut is what you need.
This, or...
...A plate was made up with two nutserts in it and held on the inside of the outer bed wall or fender while bolts were passed through the antenna bracket and threaded into two plates per mount...
This. I personally prefer this method, especially if you're adding an antenna that may get hit by things, or is heavy. Grabbing two pieces of sheet steel with a spacer and load plate on the inside squeezing the spacer together in the body panel space, will give it some structure. Using only rivnuts sounds like a good way to pull the antenna off the body panel if it strikes something (tree, bush, bicyclist... :shock:)
I saw a thread about those plates. I don't disagree but those holes appear to be in the correct place on the passenger side, just got ripped out maybe...
I don't think those holes were ever threaded or had nutserts in them from the factory, maybe a depot or field repair?
If you can't shine a flashlight into the hole and see light from underneath the truck in the body panel space, then it's probably a Rivnut - if so and there is not thread, that probably means some yahoo forgot lefty-loosy, righty-tighty and stripped them out (you'll have to drill out the old rivnut and install a new one if that is the case). If you can't shine through, it's possible the backing plate method was used to mount the antenna bracket.
...there appear to be 3 sets of '4 bolt pattern' holes (driver cab, driver tailgate, passenger cab) and the passenger tailgate just has one hole..maybe for a tie-down clip?
Tie downs I believe were two holes. One thing to remember, these vehicles have been reconfigured over the years, both by the military and after-owners (if applicable) - and with the military they often had to improvise due to time and budget constraints. Technology and usage changes constantly, they may have had an antenna in the rear and then moved it to the front (there is a model year effect on this too IIRC). For antennas that were not multiband like the military uses now, they can't co-locate an antenna, but rather have to move it a sufficient distance away from one another so they don't interfere.
...we are trying to restore the vehicle as close to how it was originally so we don't want to add any guards or antenna brackets that weren't there originally...
Based on my above comment, I'd ask if you actually know what you are trying to restore to? If you are the first owner of the truck after the military, and were trying to go to 100% military authentic, I could argue, don't touch it - it's already authentic as-is!! :naner:
nyvram
Franklin/TN
good question. its been repainted (tan over OD green) and we were thinking of going back to OD
as for the antenna holes, our thinking is that at least the brackets and bracket guards were there at one time so we wanted to put them back on where the holes are.
same for the jerry can bracket, we want to put a jerry can and bracket there because the mount is already there for it.
Warthog
241
OKC, OK
tim292stro
40
Your truck may have just had all three of those mounts installed originally depending on what use the truck had in service. I found this thread where there are three antenna mounts on the truck similar to yours. It shows the guards in addition to the mount itself, perhaps as part of the MSE system installation (now being replaced by Win-T).
The send thread Warthog linked above has some pictures I took a while back for another member - there are a few semi-close-ups of the bracket and guard about half way down in this post. The both line up for two of the four holes (at the top).
nyvram
Franklin/TN
thank you! i wish those documents were a little larger. i have a hard time reading the text even with them downloaded..if I magnify it, the words are just blurry.
intrigued by the rivnut tool and process. that seems the way we'd have to go on the one side with the dent. we probably wont install anything more than the bracket and guard there, we will probably just go with one antenna for now on the drivers side where the mounting holes seem to have plates (the 9' 3600 military 2 part mast)
...assuming of course we can find 2 more antenna brackets and 3 guards. those are hard to find.
warthog i wish i had known you (and this site) back when you had a bushel of the guards.
nyvram
Franklin/TN
thanks tim! i found that thread & downloaded those images. i dont suppose you have any higher res versions of the installation instructions do you? i downloaded the ones attached to the thread but when i enlarge them on screen, the text just gets blurry.
that truck configuration is verrry similar to ours. we would like to just put the mounts back first to 'fill in' all the holes and figure out the antennas later or if we want to use the brackets for other purposes.
tim292stro
40
The install instructions were not mine - they were from member richingalveston, just from a quick look he's been online as recently as today so shoot him a PM. If he can scan them and post them as a PDF to that thread, it'll take the full resolution BTW, and we'll all get the benefit that way.
