rustystud
- 2,742
- Woodinville, Washington
I needed to drain the fuel tank on my M1035 truck. So I made up this little pump. ![transfer fuel pump 001.jpg transfer fuel pump 001.jpg](https://www.steelsoldiers.com/data/attachments/402/402489-5087bd6b73261f735cf2aa2004f903f4.jpg)
![transfer fuel pump 005.jpg transfer fuel pump 005.jpg](https://www.steelsoldiers.com/data/attachments/402/402490-825b9535b65d04947ac9365b7881aba5.jpg)
![transfer fuel pump 006.jpg transfer fuel pump 006.jpg](https://www.steelsoldiers.com/data/attachments/402/402491-06833774efd411c0c4318db5378b2911.jpg)
![transfer fuel pump 008.jpg transfer fuel pump 008.jpg](https://www.steelsoldiers.com/data/attachments/402/402492-bcb79166aedb07d6f8d6f813f9853d21.jpg)
![transfer fuel pump 009.jpg transfer fuel pump 009.jpg](https://www.steelsoldiers.com/data/attachments/402/402493-d0467577dc80406eb739bf856c6a0571.jpg)
![transfer fuel pump 010.jpg transfer fuel pump 010.jpg](https://www.steelsoldiers.com/data/attachments/402/402494-9bbd1b6a51110186ab999d572416bc1d.jpg)
The valve on the side selects from filtered fuel to non-filtered fuel. The extra hole by the valve was a mistake. The fittings on the end are "quick disconnects" from a motorcycle. I still need to install the power lines. I figured since it's in a 50cal ammo can they should be military style connectors. So I ordered some from McMaster-Carr. This pump should move between 3 (filtered) to 5 (unfiltered) gallons of fuel a minute. There are 2 check valves to keep the fuel from backflushing into the filter. I also used DOT nylon hose. I didn't want the hoses rotting on me and then leaking all over the place in a few years.
I know it's not "official" military equipment but it will be used to "support" military equipment, so I guess that should count for something . Anyway maybe this will give others some ideas for their fuel needs.
![transfer fuel pump 012.jpg transfer fuel pump 012.jpg](https://www.steelsoldiers.com/data/attachments/402/402495-5a5046ef29151bb9683c561c78a980c1.jpg)
