74M35A2
- 330
- 83
- Livonia, MI
My ABS ECU is dead from improper shutdown. I was habitually dropping both switches to off, and would notice the volt gauge swing to red as the engine was coasting down, and then the gauge would bottom out to off. ABS 15A fuse blows as soon as replaced and battery switch is flipped on. Have ordered a new replacement ABS ECU from SUPRMAN after following those threads.
Not wanting to blow the replacement ABS ECU, I am considering to add some type of voltage limiting device. But, perhaps the PCB is supposed to be doing this, or controlling connectivity if improperly shut down? I say this because I suspect my PCB to be partially faulty somehow as I can re-engage the starter with the truck running. The truck does start, run, and all gauges work correctly. ABS did also until recently.
So I am suspecting my PCB to be somehow not functioning correct. Also it is a very high probability of improper shut down in the field, so I am assuming the PCB would normally protect against this, but mine may not be working correctly?
In summation, I am wondering if there is a known relationship between proper PCB function and protection of the ABS ECU during an improper shutdown sequence?
