Headlight conversion
tim292stro
41
S.F. Bay Area/California
If you do H4 bulbs, I like to import Osram Truckstar Pro bulbs. The difference is how they get the extra voltage support - Hella makes a 24V H4 but they double coil the filament (left), Osram uses a tighter single axis wind much like the 12V variant to get the same voltage (right).
The end result is a fuller more focussed light output. These can be imported for about the same cost as a standard 12V H4 bulb - a buck or two more if you shop around.
