- 1,958
- 277
- 83
- Colchester, VT
Lately I've got the hydraulic pump on the plow truck hooked up, as well as the joystick, control cables, and hydraulic hoses. I mounted the plow pump off the 2nd alternator bracket, it shares the belt with the alternator which used the original lower mount but is swung out further from the motor at the top. A longer belt from a HMMWV seems to be working good in that spot, Gen 2 is still charging at least and the plow goes up and down.
Today I did a little bit of welding on the push plates and started modifying a brush guard to fit with the headgear on. Hopefully I'll have it done by the time the new hydraulic hoses show up.
