Yeah I just took my truck on its first long trip 400 miles Towing a 33' 5th wheel some very steep grades High altitude and flats..
I have the Truck turned up and have a boost and egt guages a 1100 cfm air filter (550 stock) and a muffler delete kit
Total miles 400
used about 1 tank of fuel 55 gallon approx I purchased 72 gallons of fuel but cam home with way more than I left with
33' Fifth wheel right about 8-9k lbs
Saw boost as high as 30 psi
Top speed reached for short period of time 70 mph
and I did my best to keep my egts 1300 and below but this truck had my gauge easy maxed out (1500 deg) so had to down shift
I put 20oz of Radiator fluid in each tire before the trip seemed to help out a lot on the 55 mph shakes (from when i picked it up)
Engine temp never got over 200 deg
Transmission was 185-225 deg
Hit elevation as high as 7000 feet noticed a huge power loss if my math is correct a 21% LOSS
all and all truck did great and was a huge hit at the dunes and in the Parade (sand mountain NV)
Would love to see the changes in getting the timing advanced.........
