I recently acquired a MEP 803a with 363 hours. I changed both fuel filters, ensured the coolant was full, changed the oil and oil filter and recharged the original batteries that came with the unit (Optima Red Tops with 800 CCAs). Both batteries have 12.56 volts each via of a digital volt meter. I also performed a battery load test on each and they were in the acceptable range. Before I attempted to start it, I cut on the panel lights and there was nothing. Secondly, I attempted to start it by using the Master Switch and nothing. I then went to the dead crank switch and the engine turned over, but did not start.
I reviewed the TM's troubleshooting section and as a result checked the DC Control Power circuit breaker (CB1) located behind the control panel and it was energized (pushed in). There was not much else other than FU1 which was intact as well.
It seems that current is amiss somewhere. I am stumped and I am sure there are other tests I have missed.
I am requesting feedback as to what may be my dilemna. Any ideas and/or suggestions? Thanks.
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
