Replaced a red dot compressor with a newer style pan cake compressor today...oh what fun that was.
amg intake stack available for late model hmmwv's (m1113/1114/1152/1165/1167) in a crappy environment. It is just a precleaner section attached to a stack. The mushroom cap is part of the precleaner. Omega bracket holds it to the window frame.Interesting looking fording stack. Is that from some different vehicle? Is there an additional first stage air/water filter on that?
I have tried a 2 man soft top, a 4 man and a full soft ambulance soft top and my X doors all close fine and all the way with any of the above mentioned soft tops. Hope that helps.I installed hard doors.
View attachment 598448View attachment 598449View attachment 598450
BTW does anyone know if with a soft top, the latches can go to the second latching position? I have not been able to close mine tight enough to get to that second/final position.
I also installed the locking latches and retrofitted springs to keep the sliders in it from rattling too much.
.I have tried a 2 man soft top, a 4 man and a full soft ambulance soft top and my X doors all close fine and all the way with any of the above mentioned soft tops. Hope that helps.
Did you take off the soft door strikers and put on hard door strikers ?I installed hard doors.
