BOXBUILDER6971
- 3
- 0
- Dalton, GA
Hello to all who was like me in trying to find a replacement for the Military 6TN / 6TL battery. I am new here and know there are more POST about batteries. I just wanted to show everyone out here how I added 2 more batteries to my truck. I hope this may help someone else, maybe a newbie like myself to Military Trucks.
Here Is How I redone my battery box on my M932A2 5 Ton BMY. I got ripped off when I got my truck. It only had 2 batteries, with no tie downs. I read on here where a lot of people used different car batteries. I researched several options before choosing these. I first measured my battery compartment. It was basically 21" X 32". My 6TN Hawker batteries were a hair over 11" wide. I searched the web to find the biggest battery I could find to fit my box. The 8D commercial batteries had the most power, but I could not fit 2 beside each other. The 4D commercial batteries were a bit smaller but would fit. I used the truck batteries not the SOLAR Deep Cycle batteries. I used the Duracell Ultra SLI4DA with 1290 Cranking AMPS and 1050 CCA with 290 minutes reserve. Here is the link from batteries + Bulbs. https://www.batteriesplus.com/productdetails/sli4da I used the coupon CDP10011 for 10% OFF online orders For a total of $275.29 before tax for 2 batteries. I went to store and picked up. First removed the 6TN batteries to have room for the 4D batteries. They weigh right 100lbs each. I removed the boards under the 4D batteries and stacked between the 4D's for spacers. I then bought some stainless flat bar 2" wide and 3/8" thick. I cut it 13 1/2" long. I drilled a 3/8" holes through each end, and 3/4" center from each end. This gave me 12" centers between holes and used the original J hooks. I used 3/8" stainless lock nuts with nylon inserts. I used rubber belt under the stainless bar to spaces and to be more secure. You should use the vent less batteries with no caps on top. the caps will get in the way of the stainless flat bar. I used new 2/0 welding cable and crimped new ends on to make custom cables. Used heat shrink to make look neat and protect the cable. Found a diagram on the web to wire correctly. Finished connecting the cables together, checked voltage with a digital meter to make sure correct. Flipped the main switch, turned to run a moment to power the truck. Tapped the starter and about a second started like a brand new car. For all out there who want the keyed kill switch. Just remove a few boards and there is still enough room between the batteries to install the switch and cables.
