Barn find front axle p/n 937436 what do they fit
MUDDLY
FELTON,DE
Found some new front axle assy's, spicer model 30 nsn 2530-00-933-4128 with a part number 937436. Any help to there application would be a great help
quickfarms
24
Orange Junction, CA
Can you post a picture?
Open or closed knuckle?
Do they have brakes? If so disc or drum size
What is the gear ratio?
What it the length from flange to flange, where the wheel bolts to?
The MB and GPW used a model 25
The M38A1 used a model 27
Later CJ's used the model 30 in both closed and later open knuckle.
MUDDLY
FELTON,DE
Hey thanks for the info. They are closed knuckle with 4.27 ratio. According to my local salvage yard the id number 937436 comes up as m38a1. Do you think that is correct?
sunnyboy
Alice Texas
What is the width, WMS* to WMS?
*Wheel Mating Surface
I put 4.27 axles on my 61 3B, I took them of a 1970 CJ5 that had an F head 4cyl., it has the flanged rear axles, also used the T90 and transfer of it since the transmission has the lower 1st gear and the transfer has the bigger intermediate shaft. I also have an older CJ5 which also has 4.27 axles with a F head but has the older rear tapered axles.
