Are you keeping your runflats in LMTV tires?
tennmogger
556
Greenback, TN
My tires still have the runflats/beadlock donuts in them and I want to keep them for use with low tire pressure. Having the runflat might be useful in case of a tire failure.
But, it occurs to me that repairing a tire properly (with internal patch) will be almost impossible with the big rubber chunk in the way. Has anyone had to repair a tire with a runflat in place? Is there room to work around the donut?
thanks,
NDT
7,510
Camp Wood/LC, TX
Someone must have put MRAP wheel/tire assys on your LMTV because as drlivered, there are only beadlocks in the tire, not runflats.
juanprado
3,208
Metairie/La (N'awlins)
The camian wheels are identical to fmtv, same ctis plumbing also but they have run flats in them oe. Only difference is that they are stamped bae/camian in between 2 of the studs.
I use a set on the front of m923.
tennmogger
556
Greenback, TN
My tires might not have runflats! I consider that good news. The spare tires I bought, and the spare that came with it (but not on an LMTV wheel) had runflats so I made an assumption (yeah, I know).
Thanks for the insight. Still learning here.
