sandcobra164
- 323
- 83
- Leesburg, GA
I searched and didn't find anything. I've had quite a few NHC 250 powered trucks in my yard but never owned one until now. I took it for a ride around the block today but it took about 30 seconds of cranking to start it. Throttle was responsive as normal once the engine was running so I'm ruling out a fuel prime issue for now. The ether bottle is missing but the system looks intact barring that. The question I have is how often do 5 ton owners have this issue. The truck starts very quickly in 70 and 80 degree weather but it was a chilly 35 or 40 this morning. I know my old Deuce would have done it with about 2 or 3 revolutions of the engine. I do plan on installing an ether bottle but don't really like using ether. I had an M923 out here that was an RRAD rebuild and it started in weather like this similar to my Deuce. My M923 only has a little over 20,000 miles on it. I know the common phrase that you can't trust the gauges as they have probably been replaced at some point. It shows no blowby out of the crankcase breather when idling and has plenty of power so I think the rings are tight.
